RE: Extra 260 75cc
Hello bodywerks have the all up weight of the 260 came in at 22 pounds. The set up is as follows.Evolution 58 engine,1 duralite 4300 lith-ion duralite 6volt reg,1duralite 1450 lith-ion for ignition both batteries are mounted on the engine box.I Put 5955 hitec on all controls,use the smaller tank to save on weight,getting around 17 min on a tank way more than enough time for a flight.have 1.25" swb on wings and elevators,swb 4" with offset full arm for pull pull.JR 790 PCM rec,and JR 7202 for raido. useing recomended throws will do just fine.I fly imac and 3d. what I like to do is run 2 models on my radio one for imac set up and another for 3d. Oh yea im useing a evolution 24x10 prop turning 6950rpm. Hope this helps someone out there. God Bless Byron
