Fuel tank question. Multiple tanks.
Im running 4 tanks plus UAT in an aircraft im building and I was considering running a UAT to two tanks then those two tanks to another set of tanks and then running 2 vent lines out instead of a T with one vent line out. Would there be a problem with this and have you tried it? I thought 2 vent lines would alleviate the pressure of the 4 tanks. True or not? 4 tanks too much? Will the tanks still drain the same? Tell me how you set up your 4 tanks.
Scott
