RE: Pull pull setup for elevators
one more thing guys, how do you thread the two pull-pull wires through the single hole in the threaded eye bolt on the elevator servo end? do you bore the hole out a little to accommodate the two wires? i'm using the dubro 4-40 pull pull system and the hold is only wide enough to take one wire trace through it
