RCU Forums - View Single Post - GST check up
Thread: GST check up
Old 01-28-2008 | 08:20 AM
fastxr's Avatar
fastxr
Default RE: GST check up
To me they dont look broken or anything. Any other suggestions, or what am i supposed to be looking for in the clutch shoes/ springs.
Based on your pics the springs look OK (ie I dont see any of the shoes flopping around). But for a quick test you could just pull outward on the end of each cluctch shoe and see if they are have similar tension. If one shoe is much easier to pull outward than that could be the problem. I would also recheck your gap at idle in the car with the brakes on as suggested earlier. Good luck
