RCU Forums - View Single Post - First flights with new frame - glitches
Old 01-28-2008 | 10:36 AM
Skarn
Default RE: First flights with new frame - glitches
Hmm,
I would check the obvious things...if you haven't already. Make sure the crystal didn't come loose. Make sure the antenna wire or esc/servo wires aren't up against the frame. Also, do you have a ferrite ring on the wires to your esc?
That does suck, but nothing to be embarassed about!
Skarn
