RCU Forums - View Single Post - Throttle Problem
Old 01-28-2008 | 11:50 AM
Braff
Default RE: Throttle Problem
All of my servo reversing switches all in their correct position (like your picture shows). The problem with the swashplate remains - throttle up pushes swashplate up reducing blade pitch. ct420 is correct: "You can NOT use servo reversing to change the direction of an eCCPM function!" I will return controller if no one here knows a solution.
