RCU Forums - View Single Post - First flights with new frame - glitches
Old 01-28-2008 | 12:15 PM
MiniCwik's Avatar
MiniCwik
Default RE: First flights with new frame - glitches
Ahhh motor lead wires, those are the one's coming out of the motor ... right?
If so, those go under the bottom plate and then connect to the ESC under the front bottom plate. I will try and re-arrange the wires to see if that helps, along with moving the receiver antenna off of the skid (on the same side as the motor wires). Or vice versa, move the motor wires to the other skid and see if it helps.
