RE: First flights with new frame - glitches
The antenna wire goes under the bottom frame plate, to the front plastic skid support on the left side of the heli (looking from above driver's side), then goes over and back to the rear plastic skid support, then under to the front skid support and then down the antenna tube and hangs out from there, about as far back as the horizontal fin on the tail boom.
I will try and re-route the antenna wire another way, any suggestions?
