ORIGINAL: FlyFanatic
Very good, I look forward to your readings. How is engine transition, spool up, spool down with the xoar prop? Thank you for the info!
Well did't get to fly today, but I did run the os 120. It is turning 8400 to 8500 with the xoar 17x6 prop. using mach 7 15% fuel with a fireball glow plug. Using the stock muffler with the 90 deg adapter.
