RE: just bought a used t-maxx .15, some help plz
Keep this in mind also. The .15 t-,axx had stronger parts than the 3.3 parts. The only weak point I have found on the .15 is the spur gear. All of the drive shafts on the .15 are far superior in strength to the 3.3 factory drivetrain. Keep this in mind when purchasing aftermarket parts. Some things just dont need to be replaced. Even my .15's with os 18 motors are all intact with respect to drivetrain. Good luck with your build and also no one has mentioned this but I think this should be a thought for you. Instead of the short life of the 3.3, why not get an OS .18 for it. You can still get them on Feebay.
