RCU Forums - View Single Post - Seagull PC-9 Help
Old 01-29-2008 | 10:56 AM
RCVFR
My Feedback: (7)
Default RE: Seagull PC-9 Help
ORIGINAL: Pearl_414
Hi,
Well the engine is new and freshly broke-in. I adjusted the air-bleed and the high speed the same way I did for other O.S. 2 strokes I have.
Thanks again!!
You don't say what the other 2 strokes are, but if they are conventional carbs (not air bleed) that may be your problem. Conventional 2 needle carbs turn the same direction for rich/lean adjustment on both HS and LS needles. The air bleed carb LS is the opposite - turn out for lean and in for rich. Your starting point with the air bleed is to set the low end screw so you can see it at half way in the air opening, and you may need to open it (lean) from there.
