ORIGINAL: lrglnman
I have a 16-6 apc and a saito 125 .I like the combo. I started out with a Top Flight 15-8. I may still experiment with a few more props.
How are you guys lining up your elevator halfs? If not careful one side will travel farther than the other causing problems.
I take two pieces of light tubing like the inside of a Golden Rod and tape them to each elevator half. Position them so that when the elevator is centered they almost touch. Then it is real easy to see if the elevators match.
John
