RCU Forums - View Single Post - Soderung wire
Thread: Soderung wire
Old 09-21-2002 | 08:30 AM
dr_wogz
Default Soderung wire
I remeber doing the landing gear on a 1/4 scale cub. Copper wire binding three 3/16" piano wire pieces...
Clean and lightly sand teh areas to be soldered together.
Bind with the copper wire.
Apply solder flux / paste (the sluff from the plumbing store to do pipes) tot eh areas being joined.
Apply more, making sure you've got it on every parts of the steel rods. (a syringe helps here..)
Heat the whole mess with a torch. Ensure the parrts are all hot (I have a mini benzomatic, perfect for these jobs!)
The solder paste should start to flow, buble and drip all over the place!
Use silver solder, much stronger than the electrical (rosin core 63/37 - 63% lead, 37% tin) stuff..
Apply the solder, the heated assembly should suck the solder into the winding. If not, heat some more.
Help it flow into place with a popsicle stick (don't use your finger...) and scrape off any globby drips. You might have to apply a little more heat here & there..
let cool.
Remove the flux residue with Acetone, to get is all nice & shiny!!
(Remember, the flux is an acid!)
And repeat!
Use some tin foil, or a thick pice of cardboard as a heat sheild, so you don't burn other unintended parts.
I found the mni benzomatic at my local Home dep[ot store, saw it, and totally forgot what else i was shopping for. It came with a can of propane as well, good enough for a few refills. I use this for my contol rods too, soldering the clevises to the rods.
