RE: Voltmeter Question
Yes but they won't tell you much mor then there is voltage. If you have info in the pack that tells you what voltage represents what amount of charge you will be OK! But for true condition I would think you would want a tester for the battery pack, just like the garage uses to check out your cars battery under load! But smaller of coarse!
Charlie
