RE: Seagull PC-9 Help
Hi Jim,
All the engines I have are with the air-bleed setup, I don't have any engines with the conventional setup. I believe the main needle being lower then the fueltank was causing it to flood out. I'm not certain, I haven't worked on the plane since the day I went to the airport, time is short here. I may put this PC-9 on hold for now until I can get a bigger engine and buy another kit for this .40...
Thanks for the advice.
