RCU Forums - View Single Post - Beginner Boat
Old 01-29-2008 | 05:51 PM
Rich404's Avatar
Rich404
Default RE: Beginner Boat
Dieselpower,
Welcome to the scale boat hobby.
Once piece of advice that I would like to share with you especially on your first boat is.....KEEP IT SIMPLE. With many of these scale boats no matter which material used,( wood, ABS, etc) if the boat has A LOT OF DETAIL and it looks like a "masterpiece" when complete, SKIP IT. It is common for a beginner to get in over their head and become discouraged enough to not follow through on the build. Ultimately leaving the hobby with money & time wasted. Size is another factor that comes into play, the larger the boat is, the longer time it will take to complete. It is advisable to leave the big boat until you successfully complete the little boat first.......a good size range should be from 18" to 30".
Some companies offer a rating system for the different kits that they offer. look for the "beginner" level and take it from there. Keep in mind for now, "less is more".
Best of luck...
-Rich.
