RCU Forums - View Single Post - Composite ARF Impact - New Build for 2007
Old 01-29-2008 | 07:27 PM
  #50
Jeff Boyd 2's Avatar
Jeff Boyd 2
Default RE: Composite ARF Impact - New Build for 2007
Yes, there are differences . .
After tirelessly reading thread after thread, I decided on some changes. The main changes being:
1/ Made a new balsa rudder and fin post with 'V' shape hinge edge on rudder and fin.
2/ Changed the shape of the rudder and removed the counter-balance. (heard this improves things)
3/ Moved the pull-pull linkages up to roughly the centre of the rudder.
4/ Carbon Tow to strenghten and stiffen the sides of the fuse between the wing and fin post. Four of the strands run start at the wing tube.
5/ Wing adjusters with the rudder servo tray bracing the fuse.
6/ Bolly undercart and pants
JB
