RCU Forums - View Single Post - AXE CP - glitching ?
Old 01-29-2008 | 08:17 PM
r_william
Default RE: AXE CP - glitching ?
tdr1919 (Tom),
I have posted this earlier but about the same time you started this subject thread I experienced the same problem (sudden, unexplained, unwelcome shut-down). Since I had only had my Axe for about 2 weeks at that time, I was(am) not very experienced and thus not as high off the ground as you described. But the bird just shut down. While examining the bird, looking for burnt, smoking, or hot components, I heard the servos reinitialize and then repeat again while I was moving it around. Bottom line...while disconnecting the battery for safety, the battery connector (Deans???) on the ESC side had come loose and separated from the wires, both terminals. When I removed the heat-shrink it was obvious the solder conection was poorly done and only at the tips of the wire and connector pins. Very fragile. After correcting this I have had no problems since. Again to be clear, this was on the heli side of the battery connection.
RWW
