RCU Forums - View Single Post - The Long Awaited Ultra Sport 60 Build Thread
Old 01-29-2008 | 10:22 PM
  #93
MinnFlyer's Avatar
MinnFlyer
Default RE: The Long Awaited Ultra Sport 60 Build Thread
fstevenj - I used a hot bow (For cutting foam wings) to remove the excess, but it was a little tricky - especially doing it alone - because the spray foam didn't cut as easily as regular foam does. If I didn't have the hot bow, I would have probably used a hacksaw blade without the handle. I didn't have to flatten out the bottom of the wheel well because the top sheeting wasn't glued to the foam. So I just cut the circle out of the foam with a hobby knife and ripped out the excess foam with a long-nose plier. Once I got near the bottom, since it wasn't glued to the sheeting, the foam just pulled free
Bernard, both top and bottom get glassed. Then the belly pan blocks go over the fiberglass
