RCU Forums - View Single Post - Graupner MX22 & Spektrum Module
Old 01-30-2008 | 04:49 AM
digitech
My Feedback: (10)
Default RE: Graupner MX22 & Spektrum Module
ORIGINAL: modellbobby2
sandor! what the hell is your problem!
If a module (my Spektrum is a US Version) jams the tx, it is NOT OK!!!!!! it is perhaps only the voltage display but do you 100% know?
You are a bit silly to use this module on big airshows with your mx22. You maild me that you see the same voltage problem on your 2 mx22.
Everthing great! but how long!!!!
You have to change of the attitude regarding SAFETY!!
And Yes there is a new distributor in germany (JSB!!!!) And i got this information from a technical consultant. And he got this information from spektrum! OK!!!!!
the module you are using is illegal and is not allowed in europe due to high output...[:-]
you are also not insured by DMFV..if they find out.
england,s best pilots use them , the ones that dont like them use futaba
i dont have a problem
all my trannies are working fine.
they have the CE branded modules for them.
have you heard from people that have their system hung up due to this problem?
you have called me , and yes i seen this also on both my systems.
who cares , both systems use less power then with the "old" 35 mhz system.
so unless something happens i am not changing anything , because of a display flaw.
they should be going back to the old analog displays , they dont show this
ps: sorry did not know about jsb beeing a dealer for them
only seen the links on the spektrum site.
its about time they get a good guy for our market.
also try to focus on one forum and one thread
i have seen now 3 or 4 threads on different forums where you are posting about this.
JSB as a dealer or spektrum will tell you exactly what they want you to hear.
it is best to hear from experianced people that actualy use the system instead putting it under a microscope.
Spektrum had some issue,s with the old module,s about jittering .
but nothing they didnt solve with a good old firmware update.
