RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 01-30-2008 | 10:17 AM
  #2071
THRL-CKER
Default RE: gas fuel with glo plug no ignition
ORIGINAL: RysiuM
ORIGINAL: captinjohn
Rysium: Is what you are saying...is to take pure gas...then mix that with 10/10 glow fuel?
Yes, exactly. The engine will have the oil from glow fuel. It is enough for small garden engines. 10/10 glow fuel has 10% oil in it. When mixed with pure gasoline the final mix will have 3% oil, 3% nitro, 26% methanol and the rest is gasoline. It is well known AV8TOR Fuel
Your right again, I just had not done the math that works out to be 33.3:1 and I know several people that are running 100:1 in ther conventional 2 cycle engines. I remember reading in a motor cycle mag. several years ago wher they ran several dirt bikes on a dyno with diffrent oil mix's they found that there was not that much diffrence between power or longivity no matter what the oil mix was.
