RCU Forums - View Single Post - New Engine Break In
Old 01-30-2008 | 11:57 AM
  #129
Flyfalcons's Avatar
Flyfalcons
Default RE: New Engine Break In
Alta, equating a lower mix ratio oil to lesser quality is a pretty weak argument. There's a lot more that goes into the quality of oil than just the mix ratio. Stick with what your mind tells you - the facts say otherwise but as long as you are happy then good enough.
pe reviers, I just received my second DA last week, and sure enough the instruction manual still includes Amsoil 100:1 in the list of recommended oils.
