RCU Forums - View Single Post - Programming 9C
Old 01-30-2008 | 01:25 PM
marcellus
Default Programming 9C
I had my 4 servo wing glider set up as I wanted, so I know it can work the way I want it! For one reason or another I had to reprogramme the beast. I'm using glider Glid(2flp) set up, as before.
My ailerons follow flap movement & vice versa when I move aileron/speed OFS/start OFS/Butterfly, so that's all ok. My problem is snap flap. I am using Elev to Flap mix for this, actuated by switch F. The problem I have is flap goes down with up elevator, as it should but the ailerons don't move. As I said above for all other functions, they are linked to flap. I have flap to aileron activated, also actuated by switch F.
I have a 3 servo wing glider set up the same way and the two ailerons follow single flap/elevator, just the way they should.
How do I get aileron to follow flap when using snap flap?
