RE: Byron Corsair Build
I find that the plywood on the root end of the wing is not a good fit. Need to add some balsa on the bottom to bring it flush with the ply. Not a huge issue, just a bit more work. I was expecting a perfect fit, but this usualy is never the case. The leading edge matches real good and the trailing edge is slightly above the fibreglass part. This will be fixed when the flaps are done.
Craig.
