RCU Forums - View Single Post - Which glue is best for robart hinges?
Old 01-30-2008 | 08:20 PM
rgoldy
Default RE: Which glue is best for robart hinges?
For hinges-gorilla glue as it expands to fill the hole. DO NOT use gorilla on any surface that vibrates (i.e. firewall) as it ain't the strongest glue on earth in those applications. Also, for your hinges make a aluminum foil cup and melt some vaseline in it with your heat gun. Bend the hinges and dip the hinge portion in it and allow to cool. This protects the hinge area from glue (whatever you choose to use).
