RCU Forums - View Single Post - MRC THUNDER KING picture/info gallery
Old 01-31-2008 | 02:48 AM
The Boss's Avatar
The Boss
Default RE: MRC THUNDER KING picture gallery
FACTORY FRONT WHEEL TO REAR MOUNT MOD...
For guys that have extra front wheels but need rears, take a 12mm headed bolt...(maybe even a smaller 11mm bolt might work and possibly be a tighter fit on the factory 12mm hex)..., heat it up with a small torch and quickly press it into the inside of the front wheel and quickily remove it, use a correct size aluminum tube as a spacer/insulator for the hot bolt as a guide.
