Meerkat dopplered....177mph
Hey All,
I went out late afternoon yesterday to make some video attempts for sound bites so it could be Dopplered and see if my GPS readings had been close. Unfortunately, I probably only got to run about a total of 4 ounces of fuel in a total of two different flights. First flight didnt make it once around before it blew plug out. Second flight was starting to show some promise until a sheared prop in flight when the pipe started really unloading. Destroyed the Ultrathrust racing muffler, shook the firewall loose, took a little chunk out of Jett.50 crank case. Mostly fixable other than muffler, not sure of my plans there, might just put red muff back on for a while. Anyway, Mike was nice enough to do some doppler on what sound bites I had and it showed 177mph. Being that pipe never fully unloaded like other day before disaster struck, i am happy with results of 177, this plane scoots.
Ed, I was listening to you and already had some D1 props headed my way for safe factor, I just thought I could sneak in one more flight or two on sport prop. The engine must be really unloading to shear it like it did. Good news is I kept plane far enough away that no one was in real danger when it happened.
Anyway, Mike might post the doppler but hopefully it shows the plane is capable.
Mike
