RCU Forums - View Single Post - New IJMC rules.
Old 01-31-2008 | 06:20 PM
  #46
lavi rider
Default RE: New IJMC rules.
I'm not quite sure where in Israel the comp will be held at but the country has four different climate areas... in the north of the dead sea towards the galilea sea is still hot but more humid, while the dessert is hotter but dry.The sea shore area enjoys lower temp with highier humidity prcentage. The temp in the areas is as follows ...A. dessert--- +37~40 centegrade 35~40% humidity B.Galilea sea ~+ 35 ++70% humidity C. Sea shore area +31 , 60~70% humidity. D. dessert mountain area near the cities ARAD or DIMONA Temps are +31 humidity is around 35~40%.
Maybe the Hot Saunna is not that necessary....:-)
Or maybe you go as the statement " Hard in practice easy in battle!"
