RE: Carbon fiber vs Aluminum landing gear
BTW, if you use either type and it appears to be more than adequately strong for the airplane, consider using nylon bolts to attach it. If the gear is stronger than the original stuff, impacts are going right into the fuselage unless you can provide a breakaway capability. Nylon bolts provide that.
