RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 02-01-2008 | 08:34 AM
  #4772
Sikorzky
Default RE: E-FLIGHT BLADE CP
ORIGINAL: fiveoboy01
Did the fix for the sticking collective. No difference, and I suspected that it wouldn't make a difference.
Maybe I did not explain it right but the heli is jumping around without ANY stick input. Also I now do notice the tail rotor goes berserk when the collective starts jumping up and down.
It seems to only do it at high head speed(I fly in idle up mode), if I give full negative collective it stops twitching around but as I bring it back to zero pitch it starts jumping again.
This is an electronic problem having nothing to do with the sticking collective, though I'm glad I went ahead and did the mod anyways.
Anyone have any ideas? Tx batteries are brand new, I changed them just in case.
The mainshaft also looked like there was a slight wobble at the very top of the rotor head so I removed it to check. Straight as a string.
I am starting to have this same problem after 2 weeks of ownership. I notice that the up and down motion is in response to the tail motor fluctuation. It is almost like the tail motor steals some power and the main ESC is overcompensating, or lead/lagging the fluctuation. Definitely an electronic issue.
Fiveboy, how old is your Heli, was it easy to convince the tech for warranty work, and will it be free??
