RCU Forums - View Single Post - WILDHARE 29% EDGE QUESTION
Old 02-01-2008 | 01:10 PM
iowadave
Default RE: WILDHARE 29% EDGE QUESTION
I am also assembling an WG 540 edge. I noticed the Pull-Pull rudder control horns are long and limit the movement of the rubber (they hit side of fuse). On my edgs the horn is out about 1 inch from rudder (to outside edge of horn and bolt is even), Has anybody else noticed this and what did you do about it? Will I getting enough movement on the rudder any way? I have not measured the movement of the rudder as I have just installed the horns.
