RCU Forums - View Single Post - More tail feather trouble...
Old 02-01-2008 | 08:02 PM
gsoav8r
Default RE: More tail feather trouble...
This might fix you up.
You could get some 3/8 or 1/2" triangle stock to beaf it up. Mark where the reinforcement will be glued at the root and remove a small area of covering so you can epoxy the triangle stock into the corners. You want a wood to wood joint.
Youll need to do this on the top and bottom of the stabs.
Cheers.
