Airelon
Hi, I am building the Kadet LT-40, and put the left wing and airelon together. After I was finished, I noticed the airelon extends past the wing end by about 1/8" of where it was if it was perfectly lined up. How much of a problem is this. Also, when I flex the airelon directly, it takes a bit less work then when doing it by the torque rod, again, is this not normal?
Thanks.
