ORIGINAL: Raguvian
Ok, thanks. I was asking because I'm going to buy a Micro-T on Monday and I don't want to deal with the AA powered charger, and charging a 150 mah battery at 2.5A seemed a bit excessive. Some Internet research shows that they recommend you charge it at 0.3A.
150mah ? even my old AA batteries are 2500mah,and AAA 1700mah. i charge them at 2-3 amps, so that is about 1.5C charge. 0.3A is only 1A in 3 hours, is it really that low charge rate/low amp battery?
150mah and 2.5A ...yep,you´re right -it is not very good idea to charge almost 20C
