RCU Forums - View Single Post - Beryll Flight Reports?
Old 02-02-2008 | 06:54 PM
  #142
GlennBurgdorf
Default RE: Beryll Flight Reports?
I am in the process of setting up a Beryll EP and would like some thoughts on which servo's people are using.
My current plans are: JR DS8411 on ailerons and rudder and JR DS3401 on elevator.
This is the configuration of my current IC model and it seems to work well. Using the stronger servo's on ailerons seems to work better, but what are people's thoughts.
My concern with using these servos is that they may use a fair bit more current than the 40ma per flight people are reporting. My hope is to run 2 x 300ma LiPo's with a Powerbox Sensor regulator/switch.
Also, these are all metal gear servos, so there is a bit of extra weight there as well.
Any thoughts.
