RCU Forums - View Single Post - Do most ignition systems work the same?
Old 02-02-2008 | 08:46 PM
tkg
Default RE: Do most ignition systems work the same?
To many questions, but simple answer to your problem is that the RCEXL is a direct replacement for the Zenoah. You can use the Zenoah sensor, but will have to change the connector. The Zenoah color code on the sensor matches the newer RCEXL color code.
