RCU Forums - View Single Post - 50cc = 29 lbs thrust- Flight video added
Old 02-03-2008 | 09:43 AM
Ih82crash
Default RE: 50cc = 29 lbs thrust
The point where your plane hooks on appears in the video to be about 5 inches above what appears to be a hinge. The distance will create leverage and give you a higher reading. It's not that big of a deal just thought I would bring it to your attention. If you moved the eye bolt in line with your hinge my guess is you would get a different reading. Significantly less? not sure but less I am sure.
