Composite Roo 2 or 4- 8411 for elevon?
Hi Todd,
I believe your reply above to me (Craig) was meant for Johnnyjet.
But your reply does raise a question for me. As Johnnyjet is building the composite Roo, many have replied regarding using ony two BrandXXX servos. The composite Roo arrives set-up for four servos (two pre-cut and skin hinged elevons/servo wells per wing).
Those of you who are recommending two servos... are you basing your reply on the sheeted wing version of the Roo? Or are you implying that the composite Roo can somehow have it's two control surfaces per wing glued together and driven by only one high power servo?
Thanks all,
Craig
