Composite Roo 2 or 4- 8411 for elevon?
Craig,
Sorry, your right my post was intended for johnnyjet. To answer your question, you can glue the split elevons together and use one servo instead of two, in that case use the 8411's. If using split elevons then there is no need for the amount of torque the 8411's provide and suggest you use a less expensive servo like the new hitec digi's, you can buy TWO hitec 5625 servos for the price of one JR8411 with no problems. Everyone has their own opinion on which setup is better (one servo or two) but I personally have had no problems with the one servo setup. Two does offer redundancy but limited, depending on how the servo fails...Hope this clears some things up...
Todd
