RE: What do you think of FORMOST 150 ?
Sandor,
Do you have Jet A1 oleos with following dimensions ?
Mains : pivot block 1/2" - length from pivot block to wheel axle : 122 mm (minimum : 114 / max : 128 mm) - axle diameter : 4,90mm (=brass bushings) - wheel axle length : 24 mm.
Nose : pivot axle : 6 mm / wheel axle : 4,90 mm (= wheel brass bushings) - length strut : same as mains or longer (max 20mm)
Nicolas.
