RCU Forums - View Single Post - What do you think of FORMOST 150 ?
Old 02-03-2008 | 12:19 PM
SpiderJets's Avatar
SpiderJets
Default RE: What do you think of FORMOST 150 ?
ORIGINAL: SpiderJets
Sandor,
Do you have Jet A1 oleos with following dimensions ?
Mains : pivot block 1/2" - length from pivot block to wheel axle : 122 mm (minimum : 114 / max : 128 mm) - axle diameter : 4,90mm (=brass bushings) - wheel axle length : 24 mm.
Nose : pivot axle : 6 mm / wheel axle : 4,90 mm (= wheel brass bushings) - length strut : same as mains or longer (max 20mm)
Nicolas.
Sandor,
These mains look exactly like your (standard) KingCat struts ?? = 120 mm length and axle 3/16 !
For nose, the one for the Flash (138mm / 6 mm axle) could do fine... Or, even better, if you have 3/16 axle instead of 6mm... but the nose wheel brass bushings can be reamed, if needed...
Thanks !
Nicolas.
