CG
Place your initial cg at 1.5 inches behind the spar and you will be fine. Trim the plane for level flight and then roll inverted. If the plane climbs then move your cg up a bit; if it dives then move the cr aft. With a neutral cg this plane is rock solid stable and has no bad tendencies.
Mike
