RE: Badius Owners Club III
AJ, i've already cancelled the lushious looking f22 raptor twin d/f, which has two 320 watt motors already installed in the fans...for now.
the build on the kyosho shiden is coming along nicely, just finished the standard 1 hour ca'ing the tail feathers and ailerons in, the two piece wings have already got the servos installed.it's a mid wing plane and a spar goes into the box then the wing halves go on that and get bolted to the fus. last time i had to put a spar in a box on one of the hyperion scale aerobats, it took 30 minutes gentle persuasion with a hammer !!. the fin and rudder go above the fus and the tailwheel is really nice. it goes up thru the fus and then you bend it and put it in the rudder. not too tricky. next, tailfeather servos and put the wings on. pics at bedtime for you East Coasters !!
