RE: FLy Eagle Jet Models
Joe
This sounds interesting… …so the sequencer controls two servos—it allows the 1st servo to open the doors and operates the gear via the 2nd servo—correct? But one UP3 does the same—correct (I know it does, but correct)?
And the brake valve allows you to slow down your bird to a complete stop verses hitting the switch and full lockup occurs—correct?
It sounds like the UP6 does the same as the brake valve—correct?
If so to the UP3 and UP6 doing the same as all the other gadgets, wouldn’t it be cheaper and lighter just to go with the UPs?
Thanks…
Mr DJ
