RCU Forums - View Single Post - Voltmeter Question
Old 02-03-2008 | 09:22 PM
Missileman's Avatar
Missileman
Default RE: Voltmeter Question
The thing about Voltwatch, it is mounted on the airplane and you see how your battery is every time you turn the battery on.
Using a voltmeter you will not, or most people won't, check the battery every flight. If your battery goes bad you may miss it using a Voltmeter simply because you won't check as often as you will with Voltwatch.
Nothing says you can't use both, I do.
