RCU Forums - View Single Post - Thread Locker
Old 02-03-2008 | 09:27 PM
mclina's Avatar
mclina
Default RE: Thread Locker
I wouldn't use thread lock on control clevises. You'll want to adjust them for trim. You should put a piece of fuel tubing over the clevis to keep it closed.
I use thread lock on things like wheel collars, engine mounting bolts - anything that could cause serious damage if it were to come loose.
I don't use it on the screws that hold the engine together, but I re-tighten them the first time the engine gets hot. They usually stay tight after they've been tightened hot.
Good luck
