Conversion Mufflers
Aneat is right, the Al will burn away without shielding gas. Full penetration butt welds in steel will require a purge gas on the back side (usually inside of pipe) to meet some reqirements. Usually only in the nuclear field.
MIG uses a flux cored wire and does not require gas. Think of SMAW (stick welding) turned inside-out.
