Conversion Mufflers
Mike the triangular bolts are a type of thread cutting/forming bolt that they can screw into a hole without it being tapped and it will cut its own threads. It makes the weedeaters cheaper to manufacture. Going to a standard bolt may help keep them from loosening up but you can also get Locktite blue that is made for bolts to be removed and re-installed.
Adam
