Sig somethin Extra getting started, mods?
What I did was:
-Added a counter on top of the rudder. About 1 inch.
-I used the cable for the throttle but had a hard time soldering the cable to the threaded connector. When I stressed tested it it failed. So I pulled it out and replaced it with the Sullivan Flex Gold-N-Rods.
-Went with the Sullivan Flex Gold-N-Rods on the whole plane.
-Beefed up the landing gear area.
-Beefed up the tail wheel area, used a Sullivan tail wheel.
-Added brace under the wing sheeting half way between the leading edge and the spar. The sheeting is thin so this helps brace it.
Other than that it was a great plane to build.
Of course these mods are personal preference and the design looks very solid to me.
Good Luck
Bill
