RE: Raptor V1 Main Rotor Grip play
If everything is built the way it should be, I wouldn't think there should be a need to add additional shims. Pull out the manual and check things over, maybe something missing or your dampers are worn. Something doesn't sound right. I have a titan, no slack in mine when put together as per the manual.
